Using the Calendar
To specify a future time to the nearest hour, click the calendar icon. The calendar allows you to select a date first, then a time.
Entering a Time Manually
Alternatively, enter the time using this syntax:
yyyy-mm-dd hh:mm:ss (seconds optional)
or
yyyy-mm-d hh:mm:ss (seconds required)
