Note  The FME Flow Console is deprecated and will be removed from the FME Flow 2024.0 release. The FME Flow CLI, a command line interface for FME Flow, replaces the FME Flow Console. For more information, see the FME Flow CLI page.
                                                The categories of command line options are:
The first two command line option categories apply to RUN_WORKSPACE and SUBMIT_JOB commands. The last two categories apply to all commands.
