Provide a Database Server
FME Flow uses its own database to manage jobs and workspace information. It is not a source or destination data source for FME workspaces.
When configuring a fault tolerant environment for FME Flow, you must provide your own database server on which to configure the FME Flow database. Supported database servers include:
- Oracle
- PostgreSQL
- SQL Server
Provide a database server that is physically separate from the machines on which the FME Flows are installed. Separating the FME Flow Database ensures that it also remains available in a failover scenario.
When providing a database server, keep in mind the following:
- In addition to being physically separate, the database server should, by itself, be configured for fault tolerance.
- When you install the FME Flows, the database server must be running and you must know the connection information.
- If using a SQL Server database server, it must be secured with a valid SSL certificate.
- If using an Oracle database server, you must obtain the Oracle Database JDBC driver. For more information, see https://www.oracle.com/technetwork/database/application-development/jdbc/downloads/index.html.
- Following installation, you must be able to create a new database on the server using SQL scripts.
Note Oracle Database JDBC driver versions that use ojdbc10.jar are not supported.
For information about acquiring a fault tolerant database server, consult your IT department.
