Default User Accounts and Passwords
The FME Flow installer creates the following user accounts by default:
Note The default Status of these accounts, except the admin account, is Disabled.
| Username/Password | Description | Default Status | Role |
| admin/admin |
Access to all FME Flow resources. Note You are prompted to update the admin password upon initial use, based on the default Password Policy configuration.
Enabled |
fmeadmin, fmesuperuser |
author/author |
An account intended for FME Workbench authors. |
Disabled | fmeauthor |
guest/guest |
An account that provides unauthenticated access to the FME Flow Web Services. |
Disabled | fmeguest |
user/user |
An account intended for the FME Flow Web User Interface. |
Disabled | fmeuser |
See Also
