Before Installation
                                                Before you install the FME Flow components for a 2-tier system, ensure the following non-FME Flow components are in place on your network:
- Database server on a separate machine.
 - File system on a separate machine.
 - Web application server, only if you want to use your own Apache Tomcat web application server, instead of the one provided with the FME Flow installer.
Next Steps
Proceed to Obtain the Installer.
