Using the Feature Inspector
There are several ways to use the Feature Inspector to inspect or debug a workspace:
- If you already know the areas of the workspace that you want to inspect, you can set the breakpoints. When you run the workspace, the Feature Inspector will stop at each breakpoint.
- You can set the workspace to stop at each connection in the workspace (even if you have not set it as a breakpoint).
- You can run through the workspace, ignoring all breakpoints, and pause the processing at any location.
- You can set specific conditions and the Feature Inspector will stop at only the links that meet those conditions.
To run a workspace using the feature inspection capability, click the Run Workspace with Breakpoints tool:
You can also use the Ctrl+Shift+F5 keyboard shortcut.
This Feature Inspector window displays when you run a translation with feature inspection enabled. It contains a viewer, information on the feature's properties, and processing control buttons.
Viewer
The viewing area displays features for verification and debugging purposes. When the Feature Inspector stops at an inspection point, the feature will appear in the viewer. You can perform basic zoom-in and zoom-out functions, pan the area, and change the background color. In this example, the background has been changed from the default.
You can also rotate (Orbit Mode) three-dimensional features.
Contents
Exposed and Unexposed Attributes
Displays all the attributes and attribute values of the feature.
For more information, see Understanding Feature Types and Attributes.
Geometry
Displays all the geometry information for the feature, including the name of the FME Geometry Type to which the feature belongs.
Shown here are:
- Coordinate system (if applicable)
Dimension (2D or 3D)
Number of vertices
- Local coordinates of the bounding box (or cube in a 3D dataset) of the currently selected feature
- A full listing of all geometric information for the feature (coordinates for all geometry types, information about measures, transformation matrixes, raster bands, and so on).
Control Buttons
Step the translation to the next link, whether or not it is a designated breakpoint. |
Step the translation to the next breakpoint. |
Continue translation without stopping. |
Stop translation. Pressing this button will clear the Feature Inspection window. You can restart it by pressing the button. |
