Publishing to FME Flow
Open the workspace you want to publish. Click File > Publish
to FME Flow..., or click the button
on the FME Workbench toolbar.
The Publish to FME Flow wizard opens. Proceed through the panels of the wizard:
- Publish a Workspace, Transformer, or Custom Format
- Upload Connections
- Upload Packages
- Register Services
Note To publish to FME Flow, you must have an FME Flow
configured and available. For information, contact your System Administrator.
Publishing from FME Form to FME Flow When Release Builds Do Not Match
You can publish to FME Flow if your FME Form is the same release build or lower than your FME Flow. For example, FME Form build 23283 should not publish to FME Flow build 23282. To find your FME Form build, click Help from the Menu Bar and select About FME Workbench. To find your FME Flow build, see Build and Server Information in the FME Flow documentation.
