mapping file
Before FME Workbench introduced workspaces (in 2001), all translations were performed using mapping files. A mapping file (.fme file) is a series of ASCII commands that FME uses to run an translation. Mapping files can still be run through the FME Quick Translator, using functions and factories (instead of transformers) to process the data.
