Microsoft Excel Feature Representation
Features read from an Excel spreadsheet consist of a series of attribute values. By default, there is no geometry produced but points can be created by identifying x, y, and (optionally) z coordinate types for particular columns.
The attribute names are as defined in the workspace. If attribute names are not defined, then default attribute names will be created which correspond to the column index. Features being returned may not respect their schema attribute types.
In addition to the generic FME feature attributes that FME Workbench adds to all features (see About Feature Type Attributes), this format also adds format-specific attributes (Format Attributes).
| Attribute Name | Contents |
xlsx_row_id |
Row number within the file starting at 1. Produced automatically on features from the Reader. Auto-exposed on the writer. The xlsx_row_id is automatically set to this value on the writer when in Update or Delete mode, unless another attribute is explicitly chosen. |
xlsx_row_formatting |
List of name-value pairs, separated by semicolons. |
xlsx_type |
The type of geometric entity stored within the feature (Reader only). The valid values are:
Formula, Comment, Hyperlink, Formatting Column Attributes
Attribute names may also be added based on parameters set on the reader.
Attribute Name |
Reader Parameter |
Description |
<attrName>.formula |
If this parameter is selected, an attribute will be added to the workspace for columns that contain a formula. The reader reads formulas used to calculate the values of a cell and stores the formula in the attribute <attributeName>.formula. |
<attrName>.comment |
If this parameter is selected, an attribute will be added to the workspace for all columns that contain a comment. |
<attrName>.hyperlink |
If this parameter is selected, an <attributeName>.hyperlink attribute will be added to the workspace for columns that contain a hyperlink. |
<attrName>.formatting |
If this parameter is selected, an <attributeName>.formatting attribute will be added to the workspace for columns that contain formatting. |
Raster Format Attributes
During read, these attributes may be set on features. When sending a raster feature to the writer, you can add the following attributes to modify the result.
Attribute Name |
Reader/Writer |
Description |
xlsx_row_id |
Both |
Determines the row on which the top of the picture will be placed. The picture will align with the top of the row. Only positive integer values are valid. If not specified, this value will default to 1, which corresponds to row 1. |
xlsx_col_id |
Both |
Determines the column on which the left of the picture will be placed. The picture will align on the left side of the column. Only positive integer values or the Microsoft Excel Column letter designations (A,B,..,XFD) are valid. If not specified, this value will default to 1, which corresponds to column A. |
xlsx_raster_scale_factor |
Writer only |
Allows the raster to be scaled by a factor. This can be any positive numeric value greater than 0.0. If not specified, the raster will be written out using the xlsx_raster_height and xlsx_raster_width. If specified, xlsx_raster_height and xlsx_raster_width will be ignored. For example, a scale factor of 2.0 will double the width and height of the raster. If the image is larger than the height or width of a cell, the image will cover multiple cells. The cell height will not change. |
xlsx_raster_height |
Both |
Sets the raster height to the specified number of pixels. Only positive integer value greater than 0 are valid. If xlsx_raster_scale_factor is specified, this value will be ignored. If this is used, you should also specify xlsx_raster_width. If neither is specified, the raster will default to its actual size. If the image is larger than the height or width of a cell, the image will cover multiple cells. The cell height will not change. |
xlsx_raster_width |
Both |
Sets the raster width to the specified number of pixels. Only positive integer value greater than 0 are valid. If xlsx_raster_scale_factor is specified, this value will be ignored. If this is used, you should also specify xlsx_raster_height. If neither is specified, the raster will default to its actual size. If the image is larger than the height or width of a cell, the image will cover multiple cells. The cell height will not change. |
xlsx_raster_data |
Both |
If the feature does not have a raster geometry and this attribute is specified, its contents will be assumed to be an image’s binary data and will be written to the worksheet. |
xlsx_raster_format |
Reader only |
When Read Embedded Images As is set to Attributes, the image’s format will be stored in this attribute. This attribute is ignored by the writer. |
xlsx_raster_location |
Reader only |
Excel allows images external to the workbook to be displayed. These images are not directly read by the reader, and instead of xlsx_raster_data being set, this attribute will contain the file path to the raster. |
