Microsoft Azure Synapse SQL (Data Warehouse) User Attributes
Readers: For information on the parameters in this dialog that are common to all readers, see:
Writers: For information on the parameters in this dialog that are common to all writers, see:
User attributes for this format are defined below.
Name | The name of the field to be written. |
Type |
This format supports the following field types. ![]() This type is used to represent 64-bit signed integers. ![]() This type is used to represent fixed-length binary data up to a length of 8000 bytes. ![]() This type is used to represent an integer with a value of 1 or 0. ![]() This type is used to represent fixed-length character data up to a length of 8000 bytes. The number of characters that can be stored depends on the code page of the server. ![]() This type is used to represent date data from January 1, 0001 to December 31, 9999. ![]() This type is used to represent date and time data from January 1, 1753 to December 31, 9999 with an accuracy of 3.33 milliseconds. ![]() This type is used to represent date and time data from January 1, 0001 to December 31, 9999, with an accuracy of 100 nanoseconds. ![]() This type is used to represent date and time data in a specific timezone from January 1, 0001 to December 31, 9999, with an accuracy of up to 100 nanoseconds. ![]() This type is used to represent 64-bit floating precision numbers. ![]() This type is used to represent 32-bit signed integers. ![]() This type is used to represent monetary data values from -922,337,203,685,477.5808 to 922,337,203,685,477.5807. ![]() This type is used to represent fixed-length character data up to a length of 4000 Unicode UCS-2 characters. ![]() This type is used to represent fixed precision and scale numeric data from -10^38+1 to 10^38+1. ![]() This type is used to represent variable-length character data up to a length of 4000 Unicode UCS-2 characters. ![]() This type is used to represent 32-bit floating precision numbers. ![]() This type is used to represent date and time data from January 1, 1900 to June 6, 2079, with an accuracy of 1 minute. ![]() This type is used to represent 16-bit signed integers. ![]() This type is used to represent monetary data values from data values from -214,748.3648 to 214,748.3647. ![]() This type is used to represent time data with an accuracy of 100 nanoseconds. ![]() This type is used to represent numbers between 0 and 255. ![]() Uniqueidentifier is used to represent GUIDs. As such, it must be set up like a valid GUID. Example: {B85E62C3-DC56-40C0-852A-49F759AC68FB} ![]() This type is used to represent variable length binary data up to a length of 8000 bytes. ![]() This type is used to represent variable length character data up to a length of 8000 bytes. The number of characters that can be stored depends on the code page of the server. |
Index |
The types of indexes and constraints to create for the column, if the table is created. Each index and constraint contains only one column. The valid values for the column type are listed below: PrimaryKey: A primary key with non-nullable and unique constraints. Unique: An index with a unique constraint. NotNull: A non-nullable constraint. |
