FME can read and write attribute data held in dedicated SQL pools in Microsoft Azure Synapse Analytics.
FME provides read and write access via Microsoft's JDBC driver, which is bundled with FME.
Microsoft Azure Synapse SQL (Data Warehouse) Product and System Requirements
| Format | FME Platform | Operating System | ||||
| Reader/Writer | FME Form | FME Flow | FME Flow Hosted | Windows 64-bit | Linux | Mac |
| Reader | Yes | Yes | Yes | Yes | Yes | Yes |
| Writer | Yes | Yes | Yes | Yes | Yes | Yes |
The performance of this format is dependent on the amount of memory allocated to the Java Virtual Machine (JVM). The following environment variables allow you to specify memory available to Java Plugins:
FME_JVM_MIN_HEAP_SIZE
Initial heap size for initializing the JVM. If unset, the default value is 1024K.
This variable must be set in multiples of 1024 and greater than 1 MB. To indicate kilobytes, megabytes, or gigabytes, append k or K, m or M, or g or G, respectively. For example, any of these values is acceptable:
6291456
6144k
6m
FME_JVM_MAX_HEAP_SIZE
Maximum heap size for initializing the JVM. If unset, the default value is 16384K.
This variable must be set in multiples of 1024 and greater than 2 MB. To indicate kilobytes, megabytes, or gigabytes, append k or K, m or M, or g or G, respectively. For example, any of these values is acceptable:
83886080
81920k
80m
