Oracle Autonomous Spatial Object Reader/Writer
Autonomous Database includes Oracle Spatial. Oracle Autonomous Database technology was designed to deliver automated patching, upgrades, and maintenance.
FME can read and write geometric and attribute data stored using Oracle Autonomous Spatial.
Using FME with Oracle Autonomous Formats
| Oracle Format | Data Type | Characteristics |
read and write geometric and attribute data |
read and write attributes only |
Connecting to Oracle Autonomous Databases
Oracle Resources
FME Community Resources
- For information about connecting to databases, and troubleshooting connection errors, see Connecting to Oracle Autonomous Databases.
- For information about reading and writing data from Oracle Autonomous Databases, see Reading and Writing Oracle Autonomous Databases.
Format Notes
3D Geometry Support |
Reading and writing of 3D surfaces and solids is available only for Oracle 11g and above. |
Oracle Instant Client |
Instant Client can be used to run your OCI, OCCI, JDBC, and ODBC applications without installing a full Oracle Client. Instant Client supports SQL*Plus. For more information on how it works with FME, see See the FME Community for more information on how Instant Client works with FME. |
Oracle Wallet |
To use an Oracle Wallet with FME, leave the Username and Password parameters empty, and enter the name of the Oracle Wallet as the value of the Service Name or Easy Connect parameter. |
Oracle Autonomous Spatial Product and System Requirements
Format |
FME Platform |
Operating System |
Reader/Writer |
FME Form |
FME Flow |
FME Flow Hosted |
Windows 64-bit |
Linux |
Mac |
Reader |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Writer |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Reader Overview
The Oracle Autonomous Spatial Object reader reads attributes and geometry from Spatial tables in an Oracle Autonomous Data Warehouse.
Writer Overview
The Oracle Autonomous Spatial Object writer stores geometric and attribute data in an Oracle Autonomous Data Warehouse. Both uppercase and lowercase table names are supported.
The writer provides the following capabilities:
- Transaction Support: Provides transaction support that eases the data loading process. Occasionally, a data load operation terminates prematurely due to data difficulties. The transaction support provides a mechanism for reloading corrected data without data loss or duplication.
- Table Creation: Uses the information within the FME workspace to automatically create database tables as needed.
- Table Dropping: Optionally, allows each table to be written to be dropped if recreating, or truncated if appending.
- Index Creation: Sets up and populates all needed indexes and index tables as part of the loading process.
- Bulk Loading: Uses a bulk loading technique to ensure speedy data load.
