Esri Geodatabase Quick Facts
                                            Esri Geodatabase Geometry Support
                                                             Format Type Identifier  |
                                                             Operating System  |
                                                             Dependencies  |
 Note: FME and ArcGIS must both be running on 64-bit machines.  |
                                                             Dataset Type  |
                                                             Feature Type  |
                                                             Feature Class name  |
                                                             Typical File Extensions  |
                                                             Automated Translation Support  |
                                                             Yes  |
                                                             User-Defined Attributes  |
                                                             Yes  |
                                                             Coordinate System Support  |
                                                             Yes  |
                                                             Generic Color Support  |
                                                             No  |
                                                             Appearance Support (Surfaces Only)  |
                                                             Yes  |
                                                             Spatial Index  |
                                                             Always  |
                                                             Schema Required  |
                                                             Yes  |
                                                             Transaction Support  |
                                                             Yes  |
                                                             Geometry Type  |
                                                             geodb_type  |
                                                             Encoding Support  |
                                                             Yes  |
Geodatabase Raster Support
| Band Interpretations | Red8, Red16, Green8, Green16, Blue8, Blue16, Gray8, Gray16, Int8, UInt8, Int16, UInt16, Int32, UInt32, Real32, Real64 |
| Palette Key Interpretations | UInt8, UInt16 |
| Palette Value Interpretations | RGB24 |
| Nodata Value | Yes |
| Cell Origin (x, y) | 0.5, 0.5 |
| Rotation Support | No |
| GCP Support | No |
| World File Support | No |
| TAB File Support | No |
About FME and Geodatabase Rasters
Raster support is limited to File Geodatabases and Enterprise Geodatabases.
Esri Geodatabases can store rasters as raster datasets, raster catalogs, and raster mosaics.
FME Reading: FME supports reading raster datasets and raster catalogs. FME also supports reading mosaic datasets either as a single mosaicked raster through a raster dataset reader, or as multiple-source rasters through a raster catalog reader.
FME Writing: FME supports writing for raster datasets but not for raster catalogs or mosaic datasets.
