Esri Knowledge: Add Connection
Note: If the Esri ArcGIS Compatibility workspace parameter is set to Auto, and both Esri ArcMap and Esri ArcGIS Pro are installed on the system, testing a connection to an Esri Knowledge Graph may not behave as expected. To fix, uninstall Esri ArcMap, or set Esri ArcGIS Compatibility to Esri ArcMap or Esri ArcGIS Pro. For more information, see Workspace Parameters.
To define a new connection from the Connection parameter in an Esri Knowledge format:
- Select Add Database Connection. See database-specific parameters below, as well as the section Adding a Database Connection in a Workspace in Using Database Connections The new connection can be made visible only to the current user, or can be shared among multiple users.
Note: To select an existing, previously defined connection, see the section Reusing a Database Connection in Using Database Connections
Name
Enter a name for the new connection. After you save the connection, this name will be shown as a choice in the Database Connection pull-down menu whenever you are connecting to the server.
Connection Parameters
Server
The service URL for the target Knowledge Graph server.
Example: https://my-server.com/server/rest/services/Hosted/MyKnowledgeGraphName/KnowledgeGraphServer/
Username and Password
Enter the username and password for accessing the ArcGIS Portal.
