Backing Up an FME Flow Configuration
Tip To perform regularly scheduled backups, see Performing Scheduled Backups of an FME Flow Configuration.
- Select Backup & Restore > Backup. The Backup & Restore page opens on the Backup tab.
- Filename: (Optional) Edit the name of the backup file.
- Backup To:
Resource LocationSaves the backup (.fsconfig) file to a specified location on the Resources page.
- Choose Folder: Select the Resource folder to contain the backup file. To open a higher-level folder, double-click on it.
Post to Topic on Success/Failure: (Optional) FME Flow is pre-configured to publish content about the success or failure of a backup or restore operation. By default, this content is delivered to the MIGRATION_ASYNC_JOB_SUCCESS notification service topic. You can configure an Automations external action to notify you over a supported protocol when a backup or restore succeeds or fails. For more information, see Monitoring FME Flow Events from Topics.
- Click Save. The backup file saves to the specified Resource location, accompanied by a message.
Warning If you are performing a backup as part of an upgrade or re-install of FME Flow, you must select a folder that will be accessible outside of FME Flow following uninstall. Select either an Amazon Web Services (AWS) S3 bucket connection, or other network-based resource connection you created manually. All other folders will be inaccessible after FME Flow is uninstalled. Alternatively, specify Backup To: Download.
DownloadDownloads the backup (.fsconfig) file to your local system.
- Click Download. The backup file downloads.
Note On earlier versions of FME Flow, this page may be named "Migration," and the interface may not match exactly the description that follows.
See Also
