Webhook
The Webhook trigger receives JSON and other data in the body of an HTTP POST, PUT, or DELETE request message.
For the Webhook to receive a JSON-formatted request body, you must configure the message schema to match the expected data (see Output Attributes, below).
The Webhook trigger has two output ports. The success port (✔) can send a message if the trigger initiates successfully. The failure port (x) can send a message if the trigger fails to initiate.
- Webhook URL: The URL of the webhook. This parameter is auto-generated when you save the workflow. Once generated, you can click the clipboard icon to copy.
- Requires Authentication: If checked, the user that accesses the Webhook URL must have Webhooks permission on the Webhook trigger.
Output Attributes
See Also
Configuring the Webhook Schema
For the webhook to receive a JSON-formatted request body, you must configure the message schema to match the expected data, as follows:
- Under the Output Attributes tab, click Import Parameters from JSON.
- In the Import Parameters from JSON dialog, enter a valid JSON schema, and click Parse.
The imported parameters appear under "Webhook Attributes", prefixed with the webhook parent property.
Other Attributes
| Attribute | Description |
| time | Event time |
| source | Event type |
| error.type |
(Failure port only) Error type:
| error.message | (Failure port only) Error message |
| message | (Success port only) Message content |
| webhook.headers | (Success port only) The headers in the HTTP request, in the form of a JSON string. |
| webhook.method | (Success port only) The HTTP request method that triggered the webhook: POST, PUT, or DELETE. |
Working with non-JSON Data
In addition to JSON-formatted data, webhook triggers can receive text, xml, and other data. The following table explains how non-JSON data is formatted to output attributes.
Content-Type |
Message Encoding |
| text/* | Remains in text to the message attribute. |
| application/xml | Formatted as text to the message attribute. |
| application/x-www-form-urlencoded | Formatted as text to the message attribute. |
| application/* or other | Base64 to the message attribute. |
