Dropbox Directory
The Dropbox Directory trigger monitors activity on a Dropbox folder, and sends JSON messages about that activity, which can include adding, changing, and deleting files.
The Dropbox Directory trigger has two output ports. The success port (✔) can send a message if the trigger polls successfully. The failure port (x) can send a message if the trigger fails to poll.
Configuring Your Dropbox Account App
Before creating a Dropbox Directory trigger on a Dropbox account, you must configure the account with an app and generate an OAuth2 access token for it.
Tip  To test that your parameters work as expected, click Validate.
  • Access Token: Provide the OAuth2 access token for the Dropbox account you want to watch. For more information, see Configuring Your Dropbox Account App (above).
  • Path to Watch: Provide a location on your Dropbox account to watch for changes, using forward slashes. For example: /MyFolder. To specify the top-level, or 'root', use a single forward slash: /.
  • Watch Subdirectories: To watch activity in the selected directory and all subdirectories, specify Yes. To watch activity only in the selected directory and not in its subdirectories, specify No.
  • Filter: By default, all actions on the specified directory are monitored, including adding (CREATE), changing (MODIFY), and deleting (DELETE) files (and folders, if applicable). To monitor only one or two of these actions, click the "x" beside the action you do not want to monitor to remove it. To add an action after removing it, click inside the dropbox and select it.
  • Note  Events trigger based on changes in file date. If a file is overwritten, a MODIFY event is triggered.
Output Attributes
See Also
Attribute Description
time Event time
source Event type
error.type
(Failure port only) Error type:
  • InvalidMessage: An error occurred while configuring this component, such as missing or malformed values.
  • DeadLetter: An error occured while connecting to an external resource. Examples may include connection issues, invalid credentials, or generic external resource exceptions.
error.message (Failure port only) Error message
file.event (Success port only) File action (Create/Modify/Delete)
file.path (Success port only) File path
file.rootName
(Success port only) File root name
dropbox.user (Success port only) Dropbox account
