Azure Event Grid Topic
The Azure Event Grid Topic external action sends events to Microsoft Azure Event Grid topics.
The Azure Event Grid Topic external action has two output ports. The success port (✔) can send a message if the event was delivered successfully. The failure port (x) can send a message if the delivery fails.
Note  When Retry settings are configured, the failure port renders with a Retry Configured (⟳) icon.
Tip  To test that your parameters work as expected, click Validate.
  • Event Grid Topic Endpoint: The topic endpoint for the Azure Event Grid topic.
  • Note  To locate the endpoint, navigate to your topic in the Microsoft Azure portal.
  • Event Grid Topic Key: The Event Grid topic access key used to publish events to your Azure Event Grid topic.
  • Note  To locate the access key, navigate to your topic in the Microsoft Azure portal.
  • Subject: The subject to use for filtering and routing events.
  • Event Type: The event type for the specified Subject.
  • Key/Value: The event data, specified in key/value pairs, that is published to the specified Event Grid Topic Endpoint.
Output Attributes
Retry
