FME Flow Console
The FME Flow Console is a command-line utility that you can use to maintain workspaces in FME Flow repositories and run workspaces on FME Flow.
Although you can use the FME Flow Web User Interface to perform most maintenance and workflow tasks, the FME Flow Console also allows you to schedule and run batch files, and use third-party scheduling tools.
