Moving the FME Flow System Share to Another Machine
The FME Flow System Share is the location for storing Repositories and Resources. You may want to specify a new location for the System Share, and move all of its existing contents, to another networked machine.
To move the System Share, perform an upgrade operation (even if you are 'upgrading' to the same version of FME Flow). At the Install procedure (after Backup and Uninstall), select a Distributed/Fault Tolerant installation. During the install, on the FME Flow System Share dialog, specify the path to the new location. After reinstalling, perform a Restore.
