Email - SMTP
The Email - SMTP trigger allows you to configure email addresses to receive messages from SMTP email clients, and send the email data to FME Server as JSON.
The Email - SMTP trigger has two output ports. The success port (✔) can send a message if the trigger receives successfully. The failure port (x) can send a message if the trigger fails to receive.
To use the Email - SMTP trigger, you must first make sure your FME Server is properly configured to receive email. For more information see Configuring FME Server to Receive Email.
Note  The Email - SMTP trigger is not supported in a fault tolerant installation of FME Server. Consider using the Email - IMAP trigger instead.
Output Keys
Email - SMTP Trigger Log Files
Resources\logs\core\current|old\publishers\
fmepublishers.log
  • Shows some additional communication between SMTP Relay and FME Server.
email.log
  • Shows Email Received - SMTP trigger and configuring email accounts
