Run a Workspace
The Run a Workspace action receives messages from triggers or other actions and runs an FME Desktop workspace that has been uploaded to FME Server.
To use the contents of the message in the workspace, specify a workspace published parameter to receive the data. Alternatively, use readers, writers, or transformers that are equipped to receive JSON-formatted messages.
Tip
All Run a Workspace actions have success and failure output ports. The success port (✔) can send a message if the workspace completes successfully. The failure port (x) can send a message if the workspace fails to complete.
Note  When Retry settings are configured, the failure port renders with a Retry Configured (⟳) icon.
Additionally, if the specified workspace is configured with FME Server Automations writers, the Run a Workspace action contains output ports corresponding to each writer feature type.
Details
  • Action: Select Run a Workspace.
  • Repository: Specify the repository in which the workspace resides.
  • Workspace: Specify the workspace you want to run.
If the specified workspace has any published parameters, configure the settings you desire when the workspace runs.
Tip  If a newer version of the workspace is republished to FME Server while the current Run a Workspace action is open, click the Reset and Refresh Parameters button to apply any updates to published parameters.
Output Keys
Advanced
Retry
Job Statistics
You can view useful information about how a workspace has performed from a Run a Workspace action, since the workflow was last started. This information can help you make important decisions about how to run the workspace, particularly when configuring Queue Control. If the same workspace is referenced from more than one Run a Workspace action in the workflow, Job Statistics applies only to the selected action. Statistics are reset each time the workflow is started.
  • Average % CPU: Average percentage of processing time that is recorded as CPU time, calculated as Average CPU Time / Average Elapsed Time.
  • Average CPU Time: Average total CPU time to run the workspace. For more information about how CPU Time is measured, see the Completed jobs table.
  • Average Elapsed Time: Average total processing time of the workspace.
  • Average Peak Memory Usage: Average peak memory usage by the FME Engine while processing a job. For more information about how Peak Memory Usage is measured, see the Completed jobs table.
  • Total Runs: The number of times the workspace has run since the workflow was last started.
