Starting and Stopping FME Server Manually
Although the FME Server System Services start automatically, you can start and stop the services manually in the following ways:
- From the Services window (the procedure for accessing the services may vary by Windows version):
Control Panel > Administrative Tools > Services
Or
Start > Run > services.msc
In the Services window, select one or more of the services, and start or stop as required.
Linux scripts for starting and stopping FME Server are located in:
<FMEServerDir>/Server/
Although you can configure FME Server to start automatically, you can start it manually by running startServer.sh as the root user.
This script starts all the FME Server System Services in the necessary order. Alternatively, to start each service individually, run the following scripts, located in the same directory:
startCore.sh
: FME Server Core servicestartEngines.sh
: FME EnginesstartDatabaseServer.sh
: FME Server DatabasestartApplicationServer.sh
: FME Server Web Application ServerstartWebSocketServer.sh
: FME Server WebSocket ServerstartCleanup.sh
: FME Server Cleanup servicestartRootServices.sh
- Starts all the services that run as the root user. This script callsstartWebSocketServer.sh
,startCleanup.sh
, andstartApplicationServer.sh
To stop FME Server, run stopServer.sh as the root user.
Alternatively, stop the services individually with these scripts:
stopCore.sh
stopEngines.sh
stopDatabaseServer.sh
stopApplicationServer.sh
stopWebSocketServer.sh
stopCleanup.sh
stopRootServices.sh
