TopferIndexCalculator
Takes a set of point, linear, polygonal, and/or aggregate features, and calculates the Topfer Index based on user-provided source and destination scales.
The input features may be partitioned into groups based on attribute values using the Group By parameter, and one bounding box feature is output for each group. If the Group By parameter is not specified, then all input features will be processed together and a single bounding box will be output. If a given bounding box has zero area, it will become a line or a point.
To avoid the appearance of overcrowding or sparsity, maps drawn at different scales sometimes require a different level of detail. The Topfer Index is a measure used to predict how many features should be used at a new scale. The formula is given by:
n_dest = n_src * sqrt(M_src / M_dest)
where:
n_dest is the number of features that should be shown at the destination scale, also referred to here as the “Topfer Index.” This is the value that this transformer will compute.
n_src is the number of features shown at the source scale (in this case, the number of features received per group).
M_dest is the denominator of the destination scale (taken from a parameter).
M_src is the denominator of the source scale (taken from a parameter).
- To retrieve the bounds of a feature into attributes, use the BoundsExtractor.
| Group By |
One Topfer Index will be computed for each group. It will be output on each feature. |
| Complete Groups |
| Source Scale |
The denominator for the scale of the source dataset. For example, if the scale is 1:250,000, the Source Scale should be 250000. See the Topfer Index equation in the description. |
| Destination Scale |
The denominator for the scale of the destination dataset. For example, if the new potential scale is 1:500,000, the Destination Scale should be 500000. See the Topfer Index equation in the description. |
| Topfer Index |
Name the attribute to contain the Topfer Index. |
Dialog Options - Tables
