RasterCellCoercer
Creates individual points or polygons for each cell in a raster, optionally extracting band values as z coordinates or attributes.
- Converting a raster to a vector grid of polygons
- Converting a raster to regularly spaced points, either 2D or 3D
- Creating an elevation grid
- Preparing raster data for vector-based analysis
The RasterCellCoercer accepts raster input features. Depending on the choice of Output Cell Geometry - points or polygons - either a point is created at each cell origin, or a polygon is traced around the boundary of each cell.
Band values are extracted from each cell, and may be handled as either Attributes or Z Values.
If values are extracted as Attributes, they are added to a new list attribute on the output features, with one list item per band. If they are extracted as Z Values, they are assigned to the z coordinate of the output features, and they are output as 3D.
Multi-band rasters: If Z Values is used with a multi-band raster, duplicate geometry will be created for each band (which can greatly increase output size and processing time). Extracting values as Z Values is typically most appropriate for single-band numeric rasters or DEMs. If Attributes is chosen on a multi-band raster, the band values (usually representing red, green, blue, and possibly alpha values, in a range from 0 to 255) are added as list items. Color is not assigned to the output features, but may be extracted from this list attribute and assigned using a FeatureColorSetter.
Nodata values may be kept or discarded.
Input raster attributes may optionally be kept, including the Raster ID, Band ID, and source column and row position. As these options may increase processing time, by default they are not added.
This transformer supports raster band selection. The RasterSelector can be used to modify this selection.
When Extract Band Values is set to Z Values, each selected band must not contain a palette.
In this example, we will convert a DEM raster to points. The source dataset contains elevation as Band 0 values.
The raster is routed into a RasterCellCoercer.
In the parameters dialog, we select Output Cell Geometry as Points, and choose to Extract Band Values as Z Values.
Note that the Output Attribute Names do not have defaults, and so will not be created unless explicitly specified, as they can increase processing time substantially.
One point is output at the center of every cell, shown here with the original DEM displayed behind the point data. Note that the geometry is 3D, and the selected point has an elevation (z coordinate) of 60.
- This transformer can easily produce a very large number of vector features for each raster. For example a 1,000 x 1,000 RGBA image, fetched into the Z value, would produce four million point/polygon features. This can lead to the consumption of large amounts of system resources when carrying out transformation on the results, and result in writing very large output datasets.
- Very large processing tasks may benefit from using a PointCloudCombiner and PointCloudToPointCoercer as an alternate workflow (for point output only).
Choosing a Raster Transformer
Working with Rasters
RasterCellOriginSetter | Sets the cell origin point within cells in a raster. |
RasterConvolver |
RasterExpressionEvaluator | Evaluates expressions on each cell in a raster or pair of rasters, including algebraic operations and conditional statements. |
RasterExtentsCoercer | Replaces the geometry of input raster features with a polygon covering either the extents of a raster or the extent of data within a raster. |
RasterGCPExtractor | Extracts Ground Control Point (GCP) coordinate system and point values from a raster feature and exposes them as attributes. |
RasterGCPSetter | Sets Ground Control Points (GCPs) on a raster, pairing cell positions with known coordinates. |
RasterGeoreferencer | Georeferences a raster by either known corner coordinates or origin, cell size, and rotation. |
RasterHillshader | Generates a grayscale shaded relief representation of terrain, based on elevation values. |
RasterInterpretationCoercer |
RasterMosaicker | Merges multiple raster features into a single raster feature. |
RasterPropertyExtractor | Extracts the geometry properties of a raster feature and exposes them as attributes. |
RasterPyramider | Resamples rasters to multiple resolutions, based on either number of levels or dimensions of the smallest output raster. |
RasterRegisterer | Transforms an image to minimize its difference with another. |
RasterResampler | Resamples rasters, based on specified output dimensions, cell size in ground units, or percentage of original, and interpolates new cell values. |
RasterRotationApplier |
RasterSharpener | Enhances the features of a raster image. The RasterSharpener enhances the borders, lines, and curves while reducing noise in the flat areas of the raster image. |
RasterSubsetter | Clips raster features using pixel bounds instead of ground coordinates, and optionally adds cells around the perimeter. |
RasterTiler | Splits each input raster into a series of tiles by specifying either a tile size in cells/pixels or the number of tiles. |
RasterToPolygonCoercer | Creates polygons from input raster features. One polygon is output for each contiguous area of pixels with the same value in the input raster. |
WebMapTiler | Creates a series of image tiles that can be utilized by web mapping applications such as Bing™ Maps, Google Maps™, or Web Map Tile Service. This is done by resampling rasters to various different resolutions and then splitting them into tiles. |
Working with Bands
RasterBandAdder | Adds a new band to a raster feature. |
RasterBandCombiner | Merges coincidental raster features into a single output raster feature, preserving and appending all bands. |
RasterBandInterpretationCoercer |
RasterBandKeeper |
RasterBandMinMaxExtractor | Extracts the minimum and maximum band values, palette keys, and palette values from a raster feature, and adds them to a list attribute. |
RasterBandNameSetter | Sets the band name of selected bands on a raster, making raster contents simpler to understand compared to band numbers. |
RasterBandNodataRemover | Removes the existing Nodata identifier from selected bands of a raster feature. Any values previously equal to the Nodata value are considered valid data. |
RasterBandNodataSetter | Sets a new Nodata value on selected bands of a raster feature. |
RasterBandOrderer | Specifies the required order of bands in a raster. Bands are reordered according to the input band indices. |
RasterBandPropertyExtractor | Extracts the band and palette properties of a raster feature and exposes them as attributes. |
RasterBandRemover | Removes any selected bands from a raster feature. |
RasterBandSeparator | Separates bands or unique band and palette combinations, and outputs either individual raster features or a single new raster feature containing all combinations. |
RasterStatisticsCalculator | Calculates statistics on raster bands and adds the results as attributes. |
Working with Cells
RasterAspectCalculator |
RasterCellCoercer | Creates individual points or polygons for each cell in a raster, optionally extracting band values as z coordinates or attributes. |
RasterCellValueCalculator | Evaluates basic arithmetic , minimum, maximum or average operations on the cell values of a pair of rasters. |
RasterCellValueReplacer | Replaces a range of band values in a raster with a new single value. |
RasterCellValueRounder | Rounds off raster cell values. |
RasterSegmenter | Partitions a raster image into arbitrarily sized groups of cells from the input image based on intensity differences in the input raster image cells. |
RasterSingularCellValueCalculator | Performs basic arithmetic operations on the cell values of a raster against a numeric value. |
RasterSlopeCalculator | Calculates the slope (maximum rate of change in z) for each cell of a raster. |
Working with Palettes
RasterPaletteAdder |
RasterPaletteExtractor | Creates a string representation of an existing palette on a raster and saves it to an attribute. |
RasterPaletteGenerator | Generates a palette out of the selected band(s) of a raster. The output raster will have the selected band(s) replaced by a new band with a palette. |
RasterPaletteInterpretationCoercer |
RasterPaletteNodataSetter |
RasterPaletteRemover | Removes selected palette(s) from raster features. |
RasterPaletteResolver | Resolves the palette(s) on a raster by replacing cell values with their corresponding palette values. Palette values with multiple components, such as RGB, are broken down and the individual values assigned to multiple, newly-added bands. |
Workflow Control
RasterCheckpointer | Forces accumulated raster operations to be processed, saving the state to disk and releasing resources to tune performance or assist with memory limitations. |
RasterConsumer | Reads raster features for testing purposes, including any accumulated raster operations. No additional operations are performed, and nothing is done with the features. |
RasterExtractor | Serializes the geometry of a raster feature into a Blob attribute, encoding the contents according to a choice of common binary raster formats. |
RasterNumericCreator | Creates a numeric raster of specified size and resolution, with default cell values. |
RasterReplacer | Decodes a binary attribute containing encoded rasters stored as Blobs, replacing the feature’s geometry with the decoded raster. |
RasterRGBCreator | Creates a color raster feature of specified size, resolution, and interpretation type, with default cell values. |
RasterSelector |
Vectors and Rasters
ImageRasterizer | Creates a raster representation of vector or point cloud input features, using the fme_color attribute over a solid background fill for vector features. Point clouds may be rendered using their color or intensity components. |
NumericRasterizer | Creates a numeric raster representation of vector or point cloud input features, where cell values are taken from the z coordinates of the input features and overlaid on a uniform background. |
MapnikRasterizer | Generates a raster from input vector and raster features, with fine control over symbolization and labeling, using the Mapnik toolkit. |
PointCloudOnRasterComponentSetter | Sets point cloud component values by overlaying a point cloud on a raster. The component values for each point are interpolated from band values at the point location. |
PointOnRasterValueExtractor | Extracts the band and palette values from a raster at the location of one or more input points and sets them as attributes on the feature. |
RasterDEMGenerator | Produces a raster digital elevation model (DEM) by uniformly sampling a Delaunay triangulation generated from input points and breaklines. |
VectorOnRasterOverlayer | Rasterizes vector or point cloud features onto an existing raster. For vector features the fme_color attribute sets pixel color, and point clouds may be rendered using their color or intensity components. |
Points or polygons with attributes as specified in the parameters.
INVALID_RASTER_NO_BANDS
MISSING_RASTER_NO_POINTS
RASTER_ALL_CELLS_NODATA
Output Cell Geometry |
Points: One point feature will be created for each of the raster's cells, positioned at the cell's origin. Polygons: Polygon features will be output, each one covering one of the raster's cells. |
Extract Band Values As |
Attributes: One feature will be output per cell in the raster. Band and palette values will be stored in attributes named _band{}.value and _band{}.palette{}.value. The output geometry will be 2D. Z Values: One feature will be output per band per cell in the raster. The output geometry will be 3D, where the z value is the band value. |
Extract Nodata Values |
Specifies whether point features will be output for Nodata cells in the raster. Yes: A feature will be output for each Nodata cell. No: Features will not be output for Nodata cells in the raster. Note that if No is selected , and all cells in the input raster are Nodata, the feature will be rejected. |
Preserve Attributes |
Specifies whether output geometry will retain the attributes from the input raster. Note that preserving attributes may add substantial processing time, as they are added to each output feature. |
Raster ID | If specified, the name of the new attribute to contain an ID value corresponding to the original raster. |
Band ID |
If specified, the name of the new attribute to contain an ID value corresponding to the original band. Available when Extract Band Values As is set to Z Values. |
Column |
If specified, the name of the new attribute to contain the column position of the originating cell. Row 0, Column 0 corresponds to the upper-left corner. |
Row |
If specified, the name of the new attribute to contain the row position of the originating cell. Row 0, Column 0 corresponds to the upper-left corner. |
Dialog Options - Tables
Dependencies | None |
Aliases | GridPointExtractor, RasterPointExtractor, RasterToPointCoercer |
History | This transformer was previously known as the RasterToPointCoercer, RasterPointExtractor, or GridPointExtractor. |
Search for all results about the RasterCellCoercer on the FME Community.
