PROJAttributeReprojector
- Reprojecting features when explicitly using the PROJ library is desired
- Adding additional coordinate pairs as attributes, in alternate coordinate systems
The PROJAttributeReprojector accepts any feature. The user specifies the attributes containing x, y, and optionally z coordinates, and configures either an Automatic or Manual Transformation.
The transformer reprojects the coordinates according to these selections, using the PROJ reprojection library, and updates the x, y, and z attributes to the new values, overwriting the originals.
This transformer does not alter the feature’s geometry – only the values of the selected X and Y Attributes (if they contain coordinate values) are changed. Accurate results depend on the user’s correct specification of the source coordinate system.
FME currently uses PROJ version 7.x.
For Automatic transformations, the Source Coordinate System and Destination Coordinate System must be specified explicitly.
For Manual transformations, a PROJ string must be provided describing the desired transformation, as documented at PROJ’s Transformation Pipelines and shown in the examples further below. WKT2 descriptions are also valid.
Coordinate System Definitions
This transformer will accept coordinate systems defined in any one of the following forms.
Definition Style |
Example: LL-WGS84 Defined |
External Reference |
EPSG Number |
EPSG:4326 |
Well-Known Text (WKT1 or WKT2) |
GEODCRS["WGS 84", DATUM["World Geodetic System 1984", ELLIPSOID["WGS 84",6378137,298.257223563, LENGTHUNIT["metre",1.0]]], CS[ellipsoidal,2], AXIS["latitude",north,ORDER[1]], AXIS["longitude",east,ORDER[2]], ANGLEUNIT["degree",0.01745329252], ID["EPSG",4326]] |
Open Geospatial Consortium: Geographic information — Well-known text representation of coordinate reference systems Note that the EPSG website can also provide WKT strings for specific coordinate systems. |
PROJ String |
+proj=longlat +ellps=WGS84 +datum=WGS84 +no_defs |
They are fully interchangeable and can be used in any combination to define the Source and Destination Coordinate System for an Automatic transformation.
They may also be used in a PROJ string or pipeline for a Manual transformation.
Note that EPSG and WKT representations can more fully describe a coordinate system than PROJ strings, and so are the preferred definition types.
Geographic Transformations and Grids
Geographic Transformations control how coordinates are converted between different datums.
For an Automatic Transformation, FME will attempt to select an appropriate transformation between the Source and Destination coordinate systems.
Manual Transformations are performed as specified in the Manual Transformation Parameters.
Grid-Based Datum Adjustments
Some areas use grid shift files for datum conversion.
Many grids needed by PROJ are included with FME, and additional grids may be downloaded from the PROJ website.
PROJ will generally search for an appropriate grid to use, although specific paths or URLS may be specified in a transformation definition.
Grid shift files can be stored locally if preferred.
The PROJ website’s Download page includes grids, in archives named proj-data*.* To use them:
Download a proj-data archive. The Current Release version is generally appropriate. Do not use the older
proj-datumgrid*.*archives. -
Extract the archive’s contents to the ProjData directory (or a subdirectory thereof) in the FME user directory, per operating system:
~/.fme/ProjDataon Linux~/Library/Application Support/FME/ProjDataon macOSDocuments/FME/ProjDataon Windows
Grids added in this way will be considered before online grids (if enabled). They will also be considered first in order of preference, unless an absolute or relative path or URL is specified in the transformation definition.
FME can also access PROJ grids online at cdn.proj.org.
Online access may be enabled or disabled via the FME Desktop menu - Tools > FME Options > Coordinate Systems:
| Online Grids Enabled |
When enabled, PROJ in FME will search the specified CDN Endpoint for appropriate grids if necessary and according to the order of preference. Default is Enabled. |
| Maximum Cache Size (MB) |
Default is Optionally, specify a maximum size in Megabytes allotted for caching grids. |
| CDN Endpoint |
Specify a URL to access for grids. The default is provided by PROJ: https://cdn.proj.org |
PROJ will look for an appropriate grid, which can be accessed in a number of places. The search order is:
If the transformation definition contains an absolute or relative path to a grid shift file, only that file will be considered. If it cannot be found, processing terminates with an error.
If the transformation definition contains a URL for grid shift file (that is, starting with
http://orhttps://), PROJ will attempt to download the file. If it cannot be found, processing terminates with an error. -
If the transformation definition contains only a grid file name with no path or URL, PROJ will search in this order:
FME configured search paths:
Reprojectdirectory in the installation directory -
ProjDatadirectory in the FME user directory
The user-writable directory, such as:
AppData/Local/projon Windows ~/.local/share/projon Linux~/Library/Application Support/projon macOS
The list of directories specified in the
PROJ_LIBenvironment variable. -
The directory the FME workspace file is stored in (the working directory for a translation).
If the file name is not found, PROJ will search for known aliases in the same order:
eg:
ca_nrc_ntv2_0.tifhasntv2_0.gsbas an alias
If no known aliases are found, and Online Grids is enabled, PROJ will attempt to download the grid from the specified CDN Endpoint.
If networking fails, then PROJ’s options are exhausted and an error is returned.
PROJ User Data
Grids and customized proj.db files may be placed in your [FME User Directory]/ProjData folder.
Sample ProjData folder locations:
macOS |
/Users/[User]/Library/Application\ Support/FME/ProjData/ |
Windows 10 |
C:\Users\[User]\Documents\FME\ProjData |
Linux |
/home/[User]/.fme/ProjData |
PROJ transformers will give preference to files placed in this folder over other locations, including the proj.db and grid files shipped with FME.
In this example, we start with a CSV file of Historic Sites. It has no geometry, but it does contain coordinates for the sites, with a UTM Zone 10 NAD27 coordinate system. We want to reproject this to NAD83, using PROJ.
The features are routed into a PROJAttributeReprojector.
In the parameters dialog, Transformation Type is set to Manual Transformation.
The required PROJ pipeline string is entered, which references both the source and destination coordinate system definitions and the desired grid shift file.
Both the X and Y Attributes containing the coordinates are identified.
The new coordinates are calculated using the PROJ library, and replace the existing attribute values. The transformer does not create geometry, it only supplies values.
The previous example could also be performed using Well-Known Text (WKT2) to describe the transformation.
WKT2 Transformation Description
CONCATENATEDOPERATION["Inverse of UTM zone 10N + NAD27 to NAD83 (4) + UTM zone 10N",
SOURCECRS[
PROJCRS["NAD27 / UTM zone 10N",
BASEGEOGCRS["NAD27",
DATUM["North American Datum 1927",
ELLIPSOID["Clarke 1866",6378206.4,294.978698213898,
LENGTHUNIT["metre",1]]],
PRIMEM["Greenwich",0,
ANGLEUNIT["degree",0.0174532925199433]],
ID["EPSG",4267]],
CONVERSION["UTM zone 10N",
METHOD["Transverse Mercator",
ID["EPSG",9807]],
PARAMETER["Latitude of natural origin",0,
ANGLEUNIT["degree",0.0174532925199433],
ID["EPSG",8801]],
PARAMETER["Longitude of natural origin",-123,
ID["EPSG",8802]],
PARAMETER["Scale factor at natural origin",0.9996,
SCALEUNIT["unity",1],
ID["EPSG",8805]],
PARAMETER["False easting",500000,
LENGTHUNIT["metre",1],
ID["EPSG",8806]],
PARAMETER["False northing",0,
ID["EPSG",8807]]],
CS[Cartesian,2],
AXIS["(E)",east,
ORDER[1],
LENGTHUNIT["metre",1]],
AXIS["(N)",north,
ORDER[2],
ID["EPSG",26710]]],
TARGETCRS[
PROJCRS["NAD83 / UTM zone 10N",
BASEGEOGCRS["NAD83",
DATUM["North American Datum 1983",
ELLIPSOID["GRS 1980",6378137,298.257222101,
ID["EPSG",4269]],
ID["EPSG",9807]],
ID["EPSG",8801]],
ID["EPSG",8802]],
ID["EPSG",8805]],
ID["EPSG",8806]],
ID["EPSG",8807]]],
CS[Cartesian,2],
AXIS["(E)",east,
ORDER[1],
AXIS["(N)",north,
ORDER[2],
ID["EPSG",26910]]],
STEP[
CONVERSION["Inverse of UTM zone 10N",
METHOD["Inverse of Transverse Mercator",
ID["INVERSE(EPSG)",9807]],
ID["EPSG",8801]],
ID["EPSG",8802]],
ID["EPSG",8805]],
ID["EPSG",8806]],
ID["EPSG",8807]],
ID["INVERSE(EPSG)",16010]]],
STEP[
COORDINATEOPERATION["NAD27 to NAD83 (4)",
SOURCECRS[
GEOGCRS["NAD27",
CS[ellipsoidal,2],
AXIS["geodetic latitude (Lat)",north,
ORDER[1],
AXIS["geodetic longitude (Lon)",east,
ORDER[2],
ID["EPSG",4267]]],
TARGETCRS[
GEOGCRS["NAD83",
CS[ellipsoidal,2],
ORDER[1],
ORDER[2],
ID["EPSG",4269]]],
METHOD["HORIZONTAL_SHIFT_GTIFF"],
PARAMETERFILE["Latitude and longitude difference file","ca_nrc_ntv2_0.tif"],
OPERATIONACCURACY[1.5],
ID["DERIVED_FROM(EPSG)",1313]]],
STEP[
ID["EPSG",9807]],
ID["EPSG",8801]],
ID["EPSG",8802]],
ID["EPSG",8805]],
ID["EPSG",8806]],
ID["EPSG",8807]],
ID["EPSG",16010]]],
USAGE[
SCOPE["unknown"],
AREA["Canada - onshore - Alberta; British Columbia; Manitoba; New Brunswick; Newfoundland and Labrador; Northwest Territories; Nova Scotia; Nunavut; Ontario; Prince Edward Island; Quebec; Saskatchewan; Yukon; offshore east coast."],
BBOX[40.04,-141.01,83.17,-47.74]]]
This example shows the PROJAttributeReprojector parameters configured to use an epoch with a PROJ pipeline.
Note that the desired deformation model is referenced in the pipeline string.
Epochs may also be provided via an attribute value or user parameter.
- This transformer does not change the feature's coordinates – it only changes the values of the selected X, Y, and Z attributes (if they contain coordinate values).
- Earlier versions of PROJ used the proj-datumgrid grid files package, which is still available on the PROJ website. It should be replaced by the current proj-data package.
- FME has a Workspace Parameter, Reprojection Engine, that may be set to either FME (CS-Map) or Esri. This transformer will override this parameter setting.
- The AttributeReprojector provides similar functionality, and will use the default library (CS-Map or Esri) set in FME. It does not handle z values.
- To reproject coordinates stored as geometry, consider using the PROJReprojector.
- Automatic Transformations will produce a PROJ pipeline string in the log, which can be used as a template for Manual Transformations.
Coordinate System Support
Library |
FME (default) or Esri |
Library (External Links) |
Sweden |
Sweden |
Switzerland |
Features with attributes containing coordinates to be reprojected.
Features with reprojected attributes as specified in parameters.
Type
Select a method for applying a transformation.
Source Coordinate System |
If Transformation Type is Automatic Transformation, specify the coordinate system of the incoming features. The default is <Read from feature>, which reads the features’ existing coordinate system(s). Coordinate systems may also be explicitly selected from the Coordinate System Gallery, entered directly, or provided via an attribute value or user parameter. Acceptable forms include EPSG number, WKT2 string, or PROJ string (excluding pipelines). |
If Transformation Type is Automatic Transformation, specify the coordinate system to be reprojected to. Coordinate systems may be explicitly selected from the Coordinate System Gallery, entered directly, or provided via an attribute value or user parameter. Acceptable forms include EPSG number, WKT2 string, or PROJ string (excluding pipelines). Note that FME will attempt to determine what the destination coordinate system’s corresponding FME coordinate system is, and tag the output features with it, unless an override is specified by Output Coordinate System Tag. |
Epoch |
Used for spatiotemporal transformations. A decimal year that represents the time dimension to be used in the transformation pipeline. |
Transformation |
If Transformation Type is Manual Transformation, specify a complete transformation in the form of a PROJ string (including multiple-step pipelines) or WKT2. For more information see Transformation pipelines at PROJ. Note that when reprojecting rasters or point clouds, the transformation specified here must be invertible. |
X Attribute |
Provide the attribute containing the X coordinate to be reprojected. |
Y Attribute |
Provide the attribute containing the Y coordinate to be reprojected. |
Z Attribute |
Provide the attribute containing the Z coordinate to be reprojected. |
Dialog Options - Tables
Search for all results about the PROJAttributeReprojector on the FME Community.
