PointCloudStatisticsCalculator
Calculates statistics on point cloud components and adds the results as attributes.
- Inspecting and analyzing point cloud features
- Calculating statistics for use in further operations
The PointCloudStatisticsCalculator receives point cloud features and calculates selected statistics on each one individually. The results are output on each point cloud feature.
Available statistics include:
- Minimum
- Maximum
- Mean
- Sum
- Range
- Standard Deviation
- Median
- Mode
Statistics may be calculated for any or all point cloud components.
Statistics are stored as attributes, named <component>.<statisticname>, where <statisticname> will be one of the following: min, max, range, mean, stdev, sum, median, mode.
For example, if the median was calculated for component z, then an attribute named z.median would be added to the feature.
In this example, we will calculate some statistics on a LiDAR point cloud. The source data has a number of components that we may use.
The point cloud is routed into a PointCloudStatisticsCalculator.
In the parameters dialog, we select the components of interest and choose which statistics are to be calculated for each one.
The output feature has new attributes containing the requested statistics. Note that the attribute names are composed of the component name and statistic type.
- To calculate point cloud statistics on a group of point clouds as a single entity, merge them prior to this transformer with the PointCloudCombiner transformer.
Point cloud features with requested statistics added as attributes.
This table specifies which statistics to calculate for each component.
Component | Select which components to include, one per line. | ||||||||||||||||
Statistics |
The following statistics may be calculated:
Dialog Options - Tables
Dependencies | None |
Aliases | |
History |
Search for all results about the PointCloudStatisticsCalculator on the FME Community.
Keywords: point "point cloud" cloud PointCloud LiDAR sonar
