Esri Geodatabase Quick Facts
Esri Geodatabase Geometry Support
Format Type Identifier |
Reader/Writer |
Both |
Licensing Level |
Dependencies |
FME and ArcGIS must both be running on 64-bit machines. |
Dataset Type |
Feature Type |
Feature Class name |
Typical File Extensions |
Automated Translation Support |
Yes |
User-Defined Attributes |
Yes |
Coordinate System Support |
Yes |
Generic Color Support |
Appearance Support (Surfaces Only) |
Yes |
Spatial Index |
Always |
Schema Required |
Yes |
Transaction Support |
Yes |
Geometry Type |
geodb_type |
Encoding Support |
Yes |
Geodatabase Raster Support
| Band Interpretations | Red8, Red16, Green8, Green16, Blue8, Blue16, Gray8, Gray16, Int8, UInt8, Int16, UInt16, Int32, UInt32, Real32, Real64 |
| Palette Key Interpretations | UInt8, UInt16 |
| Palette Value Interpretations | RGB24 |
| Nodata Value | Yes |
| Cell Origin (x, y) | 0.5, 0.5 |
| Rotation Support | No |
| GCP Support | No |
| World File Support | No |
| TAB File Support | No |
Note: Esri Geodatabases can store rasters as raster datasets, raster catalogs, and raster mosaics. FME supports reading raster datasets and raster catalogs. In addition, FME supports reading mosaic datasets either as a single mosaicked raster through a raster dataset reader, or as multiple-source rasters through a raster catalog reader. Writing is supported for raster datasets but not for raster catalogs or mosaic datasets. Finally, raster support is limited to File Geodatabases and Enterprise Geodatabases.
