The Licensing Wizard fails with "Unable to create local license files" error message
This error indicates the Licensing Assistant was not run as Administrator.
To run the Licensing Assistant as Administrator
The Licensing Assistant is in the Start menu under FME Desktop, or fmelicensingassistant.exe in the root folder of the FME Desktop install directory. Right-click and select Run as administrator.
It may also help to delete any existing licenses from these locations:
  • The FME installation directory, under \licenses.
  • C:\ProgramData\Safe Software\FME\Licenses.
