Download and Run the Installer
The FME installer contains the utility program fme-flexnet-win-x64.msi required to get the license server up and running
To download and run
- On the FME Downloads page, specify the desired version under "Select an FME Version."
- Under "FlexNet License Server Installer for FME Desktop" click Download.
- On the computer that acts as the license server, run (double-click) the installer to create a FlexServer directory.
The following table lists the shortcuts that are created in the Safe Software program group.
Shortcut |
Description |
Generate hostid.txt |
Creates a text file that contains the hostname and Host ID information required when requesting a floating license from www.safe.com/activation/floating/. |
Launch LMTOOLS |
Launches LMTOOLS. Used for debugging or changing configuration. |
License Administration Guide |
Opens Flexera Software’s License Administration Guide. |
Start - Restart FME License Server |
Starts the license manager process. |
View FME License Server Log |
Opens the license manager log file. Used for debugging. |
View hostid.txt |
Reopens text file, if required by Safe Software. |
View Readme |
Opens the installation and configuration instructions. |
What's Next?
