DEPRECATION NOTICE: The FME Integration Console is deprecated, and will be removed from FME Desktop 2023.0.
Always make sure an application is closed before extending or reverting it in the FME Integration Console.
If an application status does not show Extended, ensure that you have the correct license for extending the application. Training licenses will not work.
