FME Server System Event
The System Event trigger sends messages about FME Server System Events.
The System Event trigger has two output ports. The success port (✔) can send a message if the trigger initiates successfully. The failure port (x) can send a message if the trigger fails to initiate.
Note: See also Working with Parameters in Automations Workflows.
- Events: Specify which System Event(s) you want to send messages.
Note: The specified System Event(s) must be enabled. For more information, see System Events.
Output Keys
For information about output keys for each system event, see Event Descriptions.
For general information, see Working with Output Keys in Automations Workflows.
The following output keys are common to all system events:
| Key | Description |
| time |
Event time |
| source | Event type |
| error.type |
(Failure port only) Error type:
| error.message | (Failure port only) Error message |
