Dropbox Directory
The Dropbox Directory trigger monitors activity on a Dropbox folder, and sends JSON messages about that activity, which can include adding, changing, and deleting files.
The Dropbox Directory trigger has two output ports. The success port (✔) can send a message if the trigger polls successfully. The failure port (x) can send a message if the trigger fails to poll.
Configuring Your Dropbox Account App
Before creating a Dropbox Directory trigger on a Dropbox account, you must configure the account with an app and generate an OAuth2 access token for it.
Output Keys
