Job Submitter Service
The Job Submitter service accepts and runs workspace job requests.
The Job Submitter service works with any workspace.
This service is requested using a URL or a form. For example,
http://Host/fmejobsubmitter/Repository/workspace.fmw?parameters
The resulting web page indicates whether the job submission was successful. If the job was submitted successfully, the FME Server transformation results are shown.
Alternatively, the job submitter service can be run from the Web User Interface.
Service Specific Request Parameters
Name
Value
Description
opt_responseformat
xml | json
Default: xml
The language of the response. The text must be all lowercase.
opt_geturl The URL to a dataset The URL of the source dataset to be used for transformation.
opt_showresult true | false Whether the XML/JSON responses include the FME transformation result. The default value is true if this parameter is not present.
opt_servicemode sync | async Toggles between synchronous and asynchronous modes of the service. When jobs are submitted asynchronously (async), the response of submission success or failure is returned immediately. When set to synchronous (sync), the response is not returned until the job completes.
opt_requesteremail
comma-separated email addresses
Addresses to which notification email messages are sent.
Job Directives and Notification Directives
This service supports Job Directives and Notification Directives.
Using Remote Data During a Request
Using data from HTTP POST body as Reader dataset
This web service can receive data and override source dataset via HTTP POST. The content of the POST request body will be saved to a temporary file which will be used as the Reader dataset of the workspace. If there is more than one reader in the workspace, then you will need to indicate which reader will use the temporary file. You indicate your choice when publishing the workspace by editing the service registration.
Using data from HTTP GET as Reader dataset
This web service can receive data and override Reader dataset via HTTP GET. The dataset should be specified as a URL and passed to service by 'opt_geturl' parameter. Both HTTP and FTP URLs are supported. If there is more than one reader in the workspace, then you will need to indicate which reader will use the temporary file. You indicate your choice when publishing the workspace by editing the service registration.
For example here is a service request that uses a remote KMZ dataset:
http://localhost/fmejobsubmitter/Test/Viewer.fmw?opt_geturl=http://data.vancouver.ca/download/kml/elementary_school_boundaries.kmz
Response Elements
If the response format is specified as XML or JSON, a service response may contain the elements shown in the following table.
Element
Child Elements
Value
Description
statusInfo
message
message string
service failure message
status
success | failure
service status
mode
sync | async
service mode
fmeTransformationResult
fmeServerResponse
FME Server response properties
FME Server response
fmeEngineResponse
FME Engine response properties
FME Engine response
email
none
Email addresses
Requesters’ email addresses
jobID
none
job ID
The current job identifier
Enabling E-Mail Notifications
The job submitter service can send email messages to notify you when a job completes successfully or unsucessfully.
For more information, see Configuring FME Server to Send Email Notifications.
See Also
