- Obtain the Installer. Be sure to obtain the FME Server Installer (not the Engine Installer).
- Start the installer on another computer (<engineHost>).
On the Installation Extractor dialog, specify a Destination folder in which to extract installation files. Note that this folder only specifies where installation files are extracted—it does not specify where FME Server program files are installed. That location is specified later in the installer.
Tip: Take note of the specified Destination folder location. Following installation, you may wish to:
Review the installation .log file.
Remove these files. Doing so saves almost 2 GB disk space.
Click Install.
- On the Choose Setup Type dialog, select the Distributed Engine setup type.
- On the Destination Folder dialog, specify the directory to install the FME Engines.
- On the User Account page, specify the Windows user account that will run the <engineHost>. This account must have:
- Read/Write access to the FME Server System Share that you specify in the next dialog. The System Share is the location where FME Server stores Repositories and Resources files.
- Read/Write access to the FME Server installation directory that you specified in the previous dialog.
- "Log on as a service" rights on the <engineHost>. For more information, see this Microsoft Docs article.
- On the Existing FME Server System Share dialog, provide the UNC path to the FME Server
System Share directory.
If the <coreHost> machine is an Express installation of FME Server, the System Share is written, by default, to %ALLUSERSPROFILE% \Safe Software\FME Server\, unless specified otherwise.
Note: Unless modified, C:\ProgramData is the default value of the %ALLUSERSPROFILE% environment variable.
In all cases, enter the UNC path to the System Share, including the final Safe Software\FME Server directories, which are created by default. For example, \\MyServer\Safe Software\FME Server.
On the FME Server Hostname dialog, enter the hostname of the <coreHost> computer.
- On the Database Server Type dialog, specify the database type that you specified when installing the FME Server Core. If you specified a database other than the "FME Server Database," enter the connection parameters in the next dialog.
- On the Database User dialog, specify the user name and password for the FME Server Database that you specified when installing FME Server.
- Complete the remaining dialogs of the FME Server Installer.
- If this <engineHost> is connecting to a <coreHost> that also hosts the built-in FME Server database and the initial FME engines, as with an Express Installation, allow the necessary connection to this machine:
- On the <coreHost>, open file pg_hba.conf, located in %ALLUSERSPROFILE%\Safe Software\FME Server\pgsql\data.
- Change the following lines:
host all all 127.0.0.1/32 md5
host all all ::1/128 md5
to:
host all all 0.0.0.0/0 md5
host all all ::/0 md5
- Restart the FME Server Database and FME Server Engines services.
- If the <coreHost> machine was an Express Installation of FME Server, complete the following steps on the <coreHost> to configure the FME Server Web Services:
- Open the corresponding propertiesFile.properties file for the Data Download, Data Streaming, Job Submitter, and Notification services, located at <FMEServerDir>\Utilities\tomcat\webapps\<service_name>\WEB-INF\conf\propertiesFile.properties.
For example, the properties file for the Data Download Service is at <FMEServerDir>\Utilities\tomcat\webapps\fmedatadownload\WEB-INF\conf\propertiesFile.properties
- For each properties file, locate the parameter REQUEST_DATA_DIR and change the value from a local file system path (for example, C:/ProgramData/Safe Software/FME Server//resources/system/temp/requestdata) to a UNC path that references the <coreHost> (for example, //MyHost/FME Server/resources/system/temp/requestdata).
Note: Use forward slashes only.
- After saving the changes in the properties file for each service, restart the FME Server Application Server service.
- On the <coreHost> machine, open configuration file fmeServerConfig.txt, located in <FMEServerDir>\Server\, and update the FME_SERVER_HOST_NAME parameter to a value that fully resolves to the IP address of the <coreHost> machine.
- Restart the FME Server Core service.
