Creating a New FME ETL Tool
The FME ETL tool is used to manipulate and transform data within the geoprocessing environment. FME ETL tools can perform format translation, and schema and geometric restructuring. For example, you can add, remove or rename attributes, and calculate or assign values to new or existing attributes.
  • Follow the instructions in ArcGIS Desktop Help for creating new toolboxes.
  • Right click on the new toolbox and choose New > FME ETL Tool from the command menu.
  • The Create Translation Workspace Wizard appears.
From the wizard:
  1. Select the Source Format
Select the format of your source data. You can also click the Browse button to choose from the Reader and Writer Gallery.
Tip: If you have data in multiple formats that you want to merge during import, choose one format here and you can add others from within Workbench. Search Adding Readers to the Workspace in Workbench Help.
  • Click Next.
  1. Locate Sample Source Data
The source datasets specified will be used to supply the source schema for the resulting tool. The resulting tool can be run on any input source datasets of the correct format.
Type the location of your input data. You can also use the buttons to browse for files or add multiple datasets. If the source format has specific default settings that you want to change, you can edit them here by clicking the Settings button. In most cases, however, the default settings will be all you need.
  • Click Next.
  1. Specify Destination Format
Choose a destination format.
Tip: If you want to export to multiple formats, choose one format here, and then you can add other export formats from within Workbench.
  • Click Next.
  1. Specify Writer Parameters
This destination format has specific settings that you can adjust. In most cases, the default settings are all you need to create the custom data export tool. However, if you want to change them, click the Parameters button.
  • Click Next.
  1. Specify Workflow Options
Choose whether to create your workspace using a Static Schema or a Dynamic Schema.
Static Schema is the default workflow and is suitable for most workspaces. The schema is read from the source dataset and is replicated on the workspace. Each reader feature type will be connected to its corresponding writer feature type.
Dynamic Schema breaks the dependence on the source and destination schema. One merged feature type will be connected to one writer feature type that is configured for dynamic operation. The schema is not replicated on the workspace; therefore, if the source data changes, you will not have to update the workspace - it will be done automatically.
  1. Click Finish to create a workspace and launch Workbench.
Use Workbench to specify the transformation of the input feature classes into output feature classes.
Using Workbench: More detailed help is available under the Workbench Help topic. For example, you might want to:
  1. When you have finished in Workbench, choose File > Exit.
What can you do with an FME ETL Tool?
