TextPropertyExtractor
Extracts the values of text attributes from input text geometry features.
Note: Feature order may change in relation to other output ports. Feature order per port is maintained.
Text String |
Name the attribute to contain the value of the input text geometry feature's fme_text_string text attribute. |
Text Size |
Name the attribute to contain the value of the input text geometry feature's fme_text_size text attribute. |
Text Rotation |
Name the attribute to contain the value of the input text geometry feature's fme_rotation text attribute. |
Dialog Options - Tables
