SQLCreator
- Extract database records as FME features according to a SQL statement
- Add features from a database mid-translation
- Execute a database join
The SQLCreator executes a SQL statement against a database. It has no input ports, and so (unlike the SQLExecutor) is not reliant on incoming features to trigger the statement - rather, the query is run one time only.
SQL statements are constructed within the transformer, using the appropriate syntax for the database in use. Spatial queries are supported if the database supports spatial predicates.
One feature is output for each row of the query results, via the Result port.
A single schema feature may also be produced if supported by the database.
In this example, we will create a set of features by querying a PostGIS database, which has a table containing addresses with point geometry. We will use a SELECT statement that extracts a subset of the data based on postal code.
A SQLCreator is placed in the workspace.
In the parameters dialog, the Database Connection is selected (or defined, if not previously saved).
A SQL statement is constructed in the SQL Statement parameter, using the built-in editor. The syntax matches the database being used.
There is a convenient shortcut in the editor - by right-clicking on a table (or column) name under Database Tables, you can create a quick statement based on SELECT and more to start editing from.
In this case, we are selecting all of the records in the PostalAddress table that have a postal code starting with V6E.
By default, the output has hidden attributes. Choose the ones you wish to include in the Attributes to Expose parameter.
The query results are extracted, including geometry. Note that only attributes which were exposed are visible in the Table View.
- If the database supports spatial predicates, spatial queries may be used.
- The SchemaScanner may also be useful as an alternative for producing schemas.
- The SQLCreator can only be used on SQL-enabled data sources. To use SQL with non-SQL data, consider the InlineQuerier.
- If all the data to be queried already exists in a SQL-capable data source, it is generally most efficient to use the SQLCreator or SQLExecutor, as the queries and filtering of the data is executed directly by the database before it enters the FME environment.
- For simple joins of one database table to features, the DatabaseJoiner may be more efficient (if the key field(s) are indexed). The DatabaseJoiner does not require knowledge of SQL.
Transformer |
Match By |
Uses SQL Statements |
Can Create List |
Input Type |
Notable |
Description |
FeatureJoiner | Attributes | No | No | Features |
Joins features by combining the attributes and/or geometry of features based on common key attribute values. Performs the equivalent of Inner, Left, and Full SQL joins. |
FeatureMerger | Attributes | No | Yes | Features |
Merges the attributes and/or geometry of one set of features onto another set of features, based on matching key attribute values and expressions. |
ListBasedFeatureMerger | List Attribute to Single Attribute | No | Yes | Features |
InlineQuerier | SQL query | Yes | No | Features |
Creates a set of SQLite database tables from incoming features, executes SQL queries against them, and outputs the results as features. |
SQLCreator | SQL query | Yes | No | External DB |
Generates FME features from the results of a SQL query executed once against a database. One FME feature is created for each row of the results of the SQL query. |
SQLExecutor | SQL query | Yes | No | External DB |
Executes SQL queries against a database. One query is issued to the database for each initiating feature that enters the transformer. Both the initiating features and the results of the query may be output as features. |
DatabaseJoiner | Attributes | No | Yes | External DB and Features |
Joins attributes from an external table to features already in a workspace, based on a common key or keys. SQL knowledge not required. Non-blocking transformer. |
Matcher | Geometry and/or Attributes | No | Yes | Features |
Detects features that are matches of each other. Features are declared to match when they have matching geometry, matching attribute values, or both. A list of attributes which must differ between the features may also be specified. If matching on attributes only (not geometry), using the FeatureMerger or another method will give better performance. |
The SQLCreator has no input ports.
If requested in parameters and supported by the database, schema features are output here.
An attribute called fme_query
is added to schema features containing the associated SQL.
Features that result from the SQL queries.
On reader errors, outputs a feature with the _reader_error attribute which contains the last error message from the reader.
Format | Select a database format. |
Dataset/Connection | According to chosen format, select a dataset or use/configure a database connection. |
Parameters | Format-specific parameters |
Coord. System |
The coordinate system of the database being connected to, as well as the coordinate system of the Result output features. Leave as default (Read from source) or use a selection from the Coordinate System Gallery. |
SQL Statement |
Specify the SQL query using the text editor. Multiple SQL commands can be delimited by a character specified using the keyword FME_SQL_DELIMITER, embedded at the very beginning of the SQL statement. The single character immediately following this keyword will be used to split the SQL which will then be sent to the database for execution. (Note: Include a space before the character.) An individual statement may be preceded with a single hyphen, indicating that errors should be ignored. Note: Some database formats support comments with /* ... */ or double hyphens (--). The following example contains two SQL commands where errors from the first command will be ignored: FME_SQL_DELIMITER ; -SELECT * FROM TABLEA; SELECT * FROM TABLEB; |
Attributes to Expose |
Enter the names of attributes to expose on the features created by the query. The attributes will be output in the same sequence as specified in the list. Note: By default, the attributes of the resulting features are hidden. You can specify which attributes to expose by entering the attribute names. Click the browse button next to the Attributes to Expose parameter. You can also use a SQL statement to populate the list by pressing “Populate from SQL Query…” and entering a SQL query. The columns from the first matching feature will be used to populate the attributes list. |
Features to Read |
Select the type of features to read and output:
Dialog Options - Tables
Not applicable |
Not applicable |
Dependencies | Format-dependent - may require third-party drivers for some formats |
Aliases | |
History |
Search for all results about the SQLCreator on the FME Community.
