RasterConsumer
Reads raster features for testing purposes, including any accumulated raster operations. No additional operations are performed, and nothing is done with the features.
Jump to Configuration
- Performance testing or benchmarking raster processing.
- Debugging raster processing.
- Testing raster feature validity.
The RasterConsumer receives raster features and reads all of their data at their current state in the workspace. It does not perform any new operations on the rasters.
FME handles rasters in a “delayed evaluation” model. A raster reader reads essential information about a raster, but does not read the actual cell contents until it is absolutely necessary. Transformer operations are accumulated until the results are needed, often being held until the features enter a writer. At that point, the required data is fully read and processed.
This is intended to optimize performance - for example, if a raster is both clipped and reprojected, FME will optimize processing by not reprojecting data that falls outside of the clip boundary and is ultimately discarded.
The RasterConsumer transformer forces this read to occur, and any accumulated operations are performed as the features are read. Nothing is done with the read features, and the transformer will not improve performance - it simply emulates the effect that reading the data would have, wherever it is placed.
It can be used to test workspace performance without configuring writers, and can also be useful for debugging raster processing workspaces with multiple accumulated operations. It may also be used for raster geometry validation, as it will reject any non-raster features.
Note: Though the transformer has parameters that can be used to adjust the way in which the raster is read (tiles), they are primarily of interest for internal Safe performance testing and are not generally useful in a production environment.
Example: Estimating raster processing time
In this example, we are building a raster processing workspace.
The source dataset is a 2 Gb GeoTIFF raster, which needs to be reprojected, then pyramided, and then passed along for further processing.
As both of these operations will be accumulated until they are required (such as enter a writer), we cannot yet determine how long it might take to process this.
A run of the workspace as it stands is very fast, an indication that the two raster operations have been held for later processing.
To get a more accurate idea of how long this will take, we add a RasterConsumer after the two raster processing transformers - the Reprojector and RasterPyramider.
In the parameters dialog, we keep the default settings.
Running the workspace again, we can see that it will take significantly more time to fully read and process the rasters, with the accumulated operations applied.
- The RasterCheckpointer similarly forces processing of any accumulated raster operations, but also writes the current state to a temporary disk file. It may be placed between raster transformers to potentially optimize processing performance and memory usage.
- The Enable Feature Caching option in FME Workbench should be disabled to obtain more accurate processing benchmarks.
Choosing a Raster Transformer
Raster Transformers
Working with Rasters
These transformers generally apply to whole rasters.
RasterCellOriginSetter
Sets the cell origin point within cells in a raster.
RasterConvolver
Applies a convolution filter (sometimes called a kernel or lens) to raster features and outputs the results.
RasterExpressionEvaluator
Evaluates expressions on each cell in a raster or pair of rasters, including algebraic operations and conditional statements.
RasterExtentsCoercer
Replaces the geometry of input raster features with a polygon covering either the extents of a raster or the extent of data within a raster.
RasterGCPExtractor
Extracts Ground Control Point (GCP) coordinate system and point values from a raster feature and exposes them as attributes.
RasterGCPSetter
Sets Ground Control Points (GCPs) on a raster, pairing cell positions with known coordinates.
RasterGeoreferencer
Georeferences a raster by either known corner coordinates or origin, cell size, and rotation.
RasterHillshader
Generates a grayscale shaded relief representation of terrain, based on elevation values.
RasterInterpretationCoercer
Alters the interpretation type of rasters, including all bands, and converts cell values if necessary.
RasterMosaicker
Merges multiple raster features into a single raster feature.
RasterPropertyExtractor
Extracts the geometry properties of a raster feature and exposes them as attributes.
RasterPyramider
RasterRegisterer
Transforms an image to minimize its difference with another.
RasterResampler
Resamples rasters, based on specified output dimensions, cell size in ground units, or percentage of original, and interpolates new cell values.
RasterRotationApplier
Rotates a raster feature according to its rotation angle property, interpolating new cell values, updating all other affected raster properties, and producing an output raster feature with a rotation angle of zero.
RasterSharpener
Enhances the features of a raster image. The RasterSharpener enhances the borders, lines, and curves while reducing noise in the flat areas of the raster image. |
RasterSubsetter
Clips raster features using pixel bounds instead of ground coordinates, and optionally adds cells around the perimeter.
RasterTiler
RasterToPolygonCoercer
Creates polygons from input raster features. One polygon is output for each contiguous area of pixels with the same value in the input raster.
WebMapTiler
Creates a series of image tiles that can be utilized by web mapping applications such as Bing™ Maps, Google Maps™, or Web Map Tile Service. This is done by resampling rasters to various different resolutions and then splitting them into tiles.
Working with Bands
Working with Cells
Working with Palettes
Workflow Control
These transformers generally control the flow of features in a workspace.
RasterCheckpointer
RasterConsumer
RasterExtractor
Serializes the geometry of a raster feature into a Blob attribute, encoding the contents according to a choice of common binary raster formats.
RasterNumericCreator
Creates a numeric raster of specified size and resolution, with default cell values.
RasterReplacer
Decodes a binary attribute containing encoded rasters stored as Blobs, replacing the feature’s geometry with the decoded raster.
RasterRGBCreator
Creates a color raster feature of specified size, resolution, and interpretation type, with default cell values.
RasterSelector
Selects specific bands and palettes of a raster for subsequent transformer operations.
Vectors and Rasters
These transformers generally involve using rasters and vector data together.
ImageRasterizer
Creates a raster representation of vector or point cloud input features, using the fme_color attribute over a solid background fill for vector features. Point clouds may be rendered using their color or intensity components.
NumericRasterizer
Creates a numeric raster representation of vector or point cloud input features, where cell values are taken from the z coordinates of the input features and overlaid on a uniform background.
MapnikRasterizer
Generates a raster from input vector and raster features, with fine control over symbolization and labeling, using the Mapnik toolkit.
PointCloudOnRasterComponentSetter
PointOnRasterValueExtractor
RasterDEMGenerator
VectorOnRasterOverlayer
Rasterizes vector or point cloud features onto an existing raster. For vector features the fme_color attribute sets pixel color, and point clouds may be rendered using their color or intensity components.
Input
Output
Raster features with no modifications made.
<Rejected>
INVALID_RASTER_NO_BANDS
Note that the default parameter settings are generally used.
Request Pattern
Tile Request Order
Tile (Default): The raster data is read one tile at a time until all tiles are consumed. Several bands may be read for a given tile.
Band: The raster data is read one band at a time until all bands are consumed.
Tile Size
Tile Size
Use source tile size (Default): The default tile size reported by the band will be used when tiles or bands are consumed.
Specify source tile size: The raster will be consumed using the specified Number of Tile Rows and Number of Tile Columns.
Number of Tile Rows
In conjunction with Specify source tile size, specify the number of rows and columns.
How to Set Parameter Values
Text Editor
Arithmetic Editor
Dialog Options - Tables
- Add a row
- Remove a row
- Move current row up one
- Move current row down one
- Move current row to top
- Move current row to bottom
- Cut a row - delete and copy to clipboard
- Copy a row to the clipboard
- Paste a row from the clipboard
Cut, copy, and paste may be used within a transformer, or between transformers.
Start typing a string, and the matrix will only display rows matching those characters. Searches all columns. This only affects the display of attributes within the transformer - it does not alter which attributes are output.
Generally resets the table to its initial state, and may provide additional options to remove invalid entries. Behavior varies between transformers.
Processing Behavior
Feature-Based
Feature Holding
No
Dependencies |
None |
Aliases |
History |
Search for all results about the RasterConsumer on the FME Community.
