EllipsePropertyExtractor
Categories
Sets the given attributes to the properties of an ellipse geometry.
Note: Feature order may change in relation to other output ports. Feature order per port is maintained.
Primary Radius |
Name the attribute to contain the length of the primary radius for the ellipse upon which the arc is based. |
Secondary Radius |
Name the attribute to contain the length of the secondary radius for the ellipse upon which the arc is based. |
Rotation |
Name the attribute to contain the rotation of the ellipse that defines the arc. The rotation angle specifies the angle in degrees from the horizontal axis to the primary axis in a counterclockwise direction. |
Orientation |
Name the attribute to contain the orientation of the ellipse that defines the arc. The orientation of a feature will follow the right-hand rule or the left-hand rule1 http://en.wikipedia.org/wiki/Right-hand_rule. |
Center X |
Name the attribute to contain the X coordinate of the center of the ellipse. If not specified, the first coordinate of the feature is used. |
Center Y |
Name the attribute to contain the Y coordinate of the center of the ellipse. If not specified, the first coordinate of the feature is used. |
Center Z |
Name the attribute to contain the Z coordinate of the center of the ellipse. If not specified, the first coordinate of the feature is used. |
Dialog Options - Tables
