CircularityCalculator
Calculates the "circularity" of an area feature, which indicates how elongated the feature is.
A value of 1 indicates that the feature is a perfect circle, and 0 indicates that it is a line.
Calculation Geometry |
If Convex Hull is specified, the convex hull of the feature is used for the calculation; otherwise, the geometry of the feature (Feature Boundary) is used. Note that long, thin polygons may still have a fairly high circularity value if they curve around in a U-shape and Convex Hull is specified. The value returned is: 4 * PI * area / (perimeter * perimeter) |
Circularity | Name the attribute to contain the angularity calculation. |
Dialog Options - Tables
