Esri Geodatabase Geometry Support
| Format Type Identifier |
| Reader/Writer | Both | |||||||||||||||||||||||||||||||||
| Licensing Level |
| Dependencies |
 FME and ArcGIS must both be running on 64-bit machines. | |||||||||||||||||||||||||||||||||
| Dataset Type |
| Feature Type | Feature Class name | |||||||||||||||||||||||||||||||||
| Typical File Extensions |
| Automated Translation Support | Yes | |||||||||||||||||||||||||||||||||
| User-Defined Attributes | Yes | |||||||||||||||||||||||||||||||||
| Coordinate System Support | Yes | |||||||||||||||||||||||||||||||||
| Generic Color Support | No | |||||||||||||||||||||||||||||||||
| Appearance Support (Surfaces Only) | Yes | |||||||||||||||||||||||||||||||||
| Spatial Index | Always | |||||||||||||||||||||||||||||||||
| Schema Required | Yes | |||||||||||||||||||||||||||||||||
| Transaction Support | Yes | |||||||||||||||||||||||||||||||||
| Geometry Type | geodb_type | |||||||||||||||||||||||||||||||||
| Encoding Support | Yes | |||||||||||||||||||||||||||||||||
Geodatabase Raster Support
| Band Interpretations | Red8, Red16, Green8, Green16, Blue8, Blue16, Gray8, Gray16, Int8, UInt8, Int16, UInt16, Int32, UInt32, Real32, Real64 |
| Palette Key Interpretations | UInt8, UInt16 |
| Palette Value Interpretations | RGB24 |
| Nodata Value | Yes |
| Cell Origin (x, y) | 0.5, 0.5 |
| Rotation Support | No |
| GCP Support | No |
| World File Support | No |
| TAB File Support | No |
Note: Esri Geodatabases can store rasters as raster datasets, raster catalogs, and raster mosaics. FME supports reading raster datasets and raster catalogs. In addition, FME supports reading mosaic datasets either as a single mosaicked raster through a raster dataset reader, or as multiple-source rasters through a raster catalog reader. Writing is supported for raster datasets but not for raster catalogs or mosaic datasets. Finally, raster support is limited to File Geodatabases and Enterprise Geodatabases.
