JMS Message
The JMS Message external action receives messages and relays them to Java Message System (JMS)-compliant message brokers, such as IBM WebSphere MQ.
The JMS Message external action has two output ports. The success port (✔) can send a message if the message broker is notified successfully. The failure port (x) can send a message if the notification fails.
Note: When Retry settings are configured, the failure port renders with a Retry Configured (⟳) icon.
Setting up a JMS Message Broker with FME Server
Before configuring a JMS Message external action, you must set up a JMS broker to work with FME Server. The steps depend on the broker you use, and are explained in the following section:
Sample Configurations
Output Keys
Retry
See Also
