Web Application Properties
                                            Upload Service Properties File Content
                                            #                       Upload Service Servlet configuration file
                                            # This file details the installation parameters of the Upload Service Servlet.
                                            # SERVER_NAME - The computer where the Transformation Manager is running. Can be specified
                                            #               as a network name (ie: "ATHENA") or an IP. The default value is
                                            #               "localhost".
                                            SERVER_NAME={{getv "/fmeserverhostnamelocal" "localhost"}}
                                            # SERVER_PORT - The port on which the Transformation Manager is running on the remote
                                            #               machine. This is an integer between 1025 and 65535.
                                            #               The default value is the default Transformation Manager listening port,
                                            #               which is 7071.
                                            SERVER_PORT={{getv "/fmeserverrequestport" "7071"}}
                                            # RESOURCE_PATH - This is the path to the textual resources of the log.
                                            #                 This file stores all the messages that will appear in the
                                            #                 log as well as their code.
                                            RESOURCE_PATH={{getv "/repositoryserverrootdir"}}/localization
                                            # ENABLE_SECURITY - A boolean value that determines if security is enabled
                                            ENABLE_SECURITY={{getv "/enablesecurity" "true"}}
                                            # SECURITY_CLIENT_ID - The identifier for this client's security context
                                            SECURITY_CLIENT_ID=service_fmedataupload
                                            # DEFAULT_USER_ID - The default user account to use when authenticating anonymously
                                            DEFAULT_USER_ID=guest
                                            # DEFAULT_PASSWORD - The default password to use when authenticating anonymously
                                            DEFAULT_PASSWORD=guest
                                            # UPLOAD_DIR
                                            UPLOAD_DIR={{getv "/repositoryserverrootdir"}}/resources/system/temp/upload
                                            # DEFAULT_FORMAT - The default response format (typically JSON)
                                            DEFAULT_RESPONSE_FORMAT=json
                                            # DEFAULT_ZIP_CODEPAGE - The default codepage used to interpret zip archived file names
                                            DEFAULT_ZIP_CODEPAGE={{getv "/zipcodepage" "CP437"}}
                                            # LOG_CONFIG_PATH - The folder path that contains the log file configuration.
                                            LOG_CONFIG_PATH={{getv "/installdir"}}/Utilities/config
                                            # LOG_FILE_NAME - The file name that the log files will have in common.
                                            LOG_FILE_NAME={{getv "/logprefix" ""}}dataupload.log
                                            #LOCALE_CONFIG_PATH - the path to the FME localization config file which contains the FME_LOCALE property
                                            #          If no file path or an invalid file path is specified, then the default system locale is used.
                                            #          If a valid file path is specified, the FME locale in the specified file is used.
                                            #          If there is no FME_LOCALE property in the file, then the default system locale is used.
                                            #          The language, country and variant are separated by underscores.
                                            #          Language is always lower case, and country is always upper case.
                                            #					 Examples: "en", "de_DE", "_GB", "en_US_WIN", "de__POSIX", "fr__MAC"
                                            LOCALE_CONFIG_PATH={{getv "/repositoryserverrootdir"}}/localization/fmeLocaleConfig.txt
                                            # CORS Shared Configuration File - File system path to the configuration file for cross-origin resource sharing that
                                            #                                  is itself shared by all FME Server services.
                                            CORS_SHARED_CONFIGURATION_FILE={{getv "/repositoryserverrootdir"}}/localization/clients/cors.properties
                                            # Charset Encoding Filter Configuration File - File system path to the configuration file for
                                            #                                              charset encoding filter.
                                            CHARSET_ENCODING_FILTER_CONFIGURATION_FILE={{getv "/repositoryserverrootdir"}}/localization/clients/charsetEncoding.properties
