The FME Server Console is a command-line utility that you can use to maintain workspaces in FME Server repositories and run workspaces on FME Server.
Although you can use the FME Server Web User Interface to perform most maintenance and workflow tasks, the FME Server Console also allows you to schedule and run batch files, and use third-party scheduling tools.
See Also
