Azure Event Grid Publisher
The Azure Event Grid publisher receives Microsoft Azure events and notifies topics about them.
Note: The FME Server must be publicly accessible with a valid SSL certificate. For more information, see Configuring for HTTPS.
Protocol Settings
  • Webhook Endpoint: The WebHook endpoint from which to receive events.
  • Note: The id segment acts as an access token to verify that the event is coming from Azure Event Grid, and should be kept private.
