FME Server uses its own database to manage jobs and workspace information. It is not a source or destination data source for FME workspaces.
To ensure the FME Server Database remains available in a failover scenario, provide a machine on which to install the database that is physically separate from the machines on which the FME Servers are installed. In addition to being physically separate, the database server should, by itself, be configured for fault tolerance.
You can choose to install a PostgreSQL database that is included with the FME Server installer, or you can configure the FME Server Database on your own database server. If you use your own database server, keep in mind the following:
- PostgreSQL, Oracle, and SQL Server are supported. The following versions are recommended:- PostgreSQL: 11.x or later.
- Oracle: 12c or later.
- SQL Server: 2016 or later.
- When you install the FME Servers, the database server must be running and you must know the connection information.
- If using an Oracle database server, you must obtain the Oracle Database JDBC driver. For more information, see https://www.oracle.com/technetwork/database/application-development/jdbc/downloads/index.html.
- Following installation, you must be able to create a new database on the server using SQL scripts.
Note: Oracle Database JDBC driver versions that use ojdbc10.jar are not supported.
For information about acquiring a fault-tolerant database server, consult your IT department.
Updating the FME Server Database Password
If you choose to install a PostgreSQL database that is included with the FME Server installer, and want to update the password for the database user account, follow these instructions:
 Expand for instructions - Windows
                                            - Start pgAdmin4.exe from <FMEServerDir>\Utilities\pgsql\pgAdmin 4\bin\.
- If this is your first time starting pgAdmin4, it will prompt you to set a master password. Choose something you will remember.
- If pgAdmin auto-connects to the FME Server Database, an entry appears in the Object browser, under Servers, similar to the following:
- Right-click on Servers and Select Create > Server....
- In the General tab of the Create - Server dialog, specify the Name for the server connection. This can be anything, such as fmeserver.
- In the Connection tab of the Create - Server dialog, specify the server properties, using the Database Connection details in the fmeDatabaseConfig configuration file, for DB_TYPE=postgresql, as follows:
- Click Save.
- In the Object browser, select the FME Server Database server, and locate and expand Login/Group Roles.
- Right-click the fmeserver database user account and select Properties. Under Definition, change the Password and click Save.
- In the fmeDatabaseConfig configuration file, update the value of the DB_PASSWORD parameter that corresponds to DB_TYPE=postgresql with the new password specified above.
- (Recommended) Encrypt the FME Server Database password.
- Restart FME Server.
fmeserver (<hostname>:7082)
If pgAdmin III does not auto-connect to the FME Server Database, add a new Server for it. To add a New Server:
| Property | Value from fmeDatabaseConfig.txt |
| Host name/address | DB_JDBC_URL=jdbc:postgresql://<hostname>:<port>/<database_name> |
| Port | DB_JDBC_URL=jdbc:postgresql://<hostname>:<port>/<database_name> |
| Maintenance database | DB_JDBC_URL=jdbc:postgresql://<hostname>:<port>/<database_name> |
| Username | DB_USERNAME=<username> |
| Password | DB_PASSWORD=<password> |
When finished, save the file.
 Expand for instructions - Linux
                                            - Open a command prompt and change to the following directory:
- Run the following command to connect to the FME Server Database:
- Once connected, enter the following command to change the password for your user:
                                                        Use \q to quit psql.
- In the the fmeDatabaseConfig configuration file, update the value of the DB_PASSWORD parameter that corresponds to DB_TYPE=postgresql with the new password specified above, and save the file.
<FMEServerDir>/Utilities/pgsql/bin
./psql -d <databaseName> -p <port> -U <username>
To confirm the settings, check the Database Connection details in the fmeDatabaseConfig configuration file, for DB_TYPE=postgresql, as follows:
| -d | DB_JDBC_URL=jdbc:postgresql://<hostname>:<port>/<database_name> |
| -h | DB_JDBC_URL=jdbc:postgresql://<hostname>:<port>/<database_name> |
| -p | DB_JDBC_URL=jdbc:postgresql://<hostname>:<port>/<database_name> |
| -U | DB_USERNAME=<username> |
| Password ( when prompted) | DB_PASSWORD=<password> |
\password
