Installing the JMS Libraries
An installation of FME Desktop includes the libraries that are required for using JMS messaging with Apache ActiveMQ 5.6.0. For all other message brokers, vendor-specific JMS libraries must be acquired and installed alongside FME Server.
Typically, vendor-specific JMS libraries are either available in the message broker’s installation, or available in a separate message broker client. In the case of IBM WebSphere MQ 7, for example, a separate client installation is available.
The table below provides links to appropriate software. For additional information, consult your vendor's documentation.
To install the JMS Libraries
- Download and install the software containing the vendor-specific JMS implementation library to the machine with the installation of FME Desktop.
- Locate the required libraries. (See the table below, under "Libraries.")
- Copy the libraries to the \plugins folder, located directly under the root directory of your FME installation.
Message Broker | Libraries | Sample Path (Windows) |
Apache ActiveMQ | none (Apache ActiveMQ 5.6.0 libraries bundled with FME Desktop) | -- |
IBM WebSphere 7 |
com.ibm.mq.jmqi.jar com.ibm.mqjms.jar dhbcore.jar fscontext.jar providerutil.jar |
C:\Program Files (x86)\IBM\WebSphere MQ\java\lib |
IBM MQ 9.2 |
com.ibm.mq.allclient.jar jms.jar fscontext.jar providerutil.jar |
C:\Program Files\IBM\MQ\java\lib |
HornetQ |
hornetq-jms.jar hornetq-jms-client.jar jnp-client.jar |
C:\hornetq-x.y.z\lib |
Oracle Weblogic | wlthint3client.jar |
What's Next?
Depending on your message broker, additional configuration may be required to enable JMS. See Configuring the JMS Provider
