WhiteStarLeaseBuilder
Posts a query to a WhiteStar Legal2Map™ WebServices (WS3) server to obtain points or polygons matching a list of legal land descriptions.
A feature is emitted for each point or polygon returned from the query.
Request Parameters
Connection Parameters
HTTP Authentication Parameters
Example
The query for well locations described by the queries "6 25S 21E 1 SE SE SE NW" and "6 10S 16W 2 C SE NE SW" is formed as follows:
  1. The input feature contains the attribute request{0} and request{1} with the values:
request{0} = "6 25S 21E 1 SE SE SE NW"
request{1} = "6 10S 16W 2 C SE NE SW"
  1. "Request Description Attribute" is set to "request{}"
  2. "Result Description Attribute" is set to "_description"
  3. "Transaction ID attribute" is set to "_trans_id"
  4. "Resulting Geometry Type" is set to "Point".
  5. Web service host, username, and password are entered for the target server.
Execution of this query results in the following two features:
IFMEPoint (-95.052404999999993,37.900077000000003)
_description -> `6 25S 21E 1 SESESENW'
_trans_id -> `871'
fme_geometry -> `fme_point'
fme_type -> `fme_point'
IFMEPoint (-99.076954999999998,39.209764999999997)
_description -> `6 10S 16W 2 CSENESW'
_trans_id -> `871'
Dialog Options - Tables
