VoronoiDiagrammer
Generates a Voronoi diagram or Thiessen polygon.
A Voronoi diagram is a set of polygons that represent proximity information about a set of input points. Each polygon in the diagram defines the area of space that is closest to a particular input point.
Note: If a Voronoi diagram is to be made from points with elevations, and you want to add additional breakline and tolerance options, consider using the SurfaceModeller transformer.
Example
Dialog Options - Tables
Keywords: MBR "minimum bounding rectangle" VoronoiDiagram
